hello please help me i have some problem( System error E007 ) in Canon iR-2016 copier machine how i can solved this problem? Thanks
AnonymousDec 05, 2007
I ALSO HAVE THE SAME PROBLEM..CAN SOMEBODY SAW ME THE STEPS TO CHECK WHERE THE SENSOR IS?? I ALSO HAVE THE SAME PROBLEM..CAN SOMEBODY SAW ME THE STEPS TO CHECK WHERE THE SENSOR IS??
Hi please help me to fix Error EXXX " all error " on Canon IR2016 . thank you in advance..Hi please help me to fix Error EXXX " all error " on Canon IR2016 . thank you in advance..
AnonymousFeb 28, 2008
Ouvir dizer que se refere ao rompimento de uma película protetora.Ouvir dizer que se refere ao rompimento de uma película protetora.
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
<quote> How to reset E000, E001, E003 and E007 Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Did you put back the green jam release lever when you replaced the film.
or did you add a printer kit.
For the E007 check if the new film is rotating in the same speed as the presure roller, check if you mounted the film sensor corectly, and if the sensor is reading the corect end of the film ( it schould be the one whit a white square on it).
Please revert me, if you need more assistance, i would be very glad to assist you more. If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa! Vinod Kumar J
Hi
I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error
E007 .. and some times when i turn on the copier it shows this error
. How can I Fix this error ... please help me .
E 007
Thanks
Hi
fastinnerhtml!
I have system error code E007
on a Canon ir2016.
How do i solve the problem?
Thanks
my email:[email protected]
