My sister has a 2000 Toyota Sienna minivan. Just recently her automatic key lock stop working. So now when she unlocks her doors with the key (the old fashion way) her van alarm goes off. The alarm stops when she puts the key in the ignition and starts the van. She has changed the battery in her key lock but that does not work. We appreciate it any help you can give. I know our neighbors would appreciate too. Thank you and have a great day.
1. Start with key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into ignition (Do not turn) and pull it out.
3. Perform these steps within 40 seconds.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
with lock. Use an even pace and try to go about one cycle per second.
(1 cycle = 1 lock and 1 unlock.)
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
7. Close drivers door.
My toyota minivan 2000 had broken Handle/latch on real door, soon I replaced handle I can not open any more, even inside
Thanks
Than
