SanDisk Sansa c140 MP3 Player Logo
Posted on Sep 26, 2007
Frozen screen ok, so with my sandisk c140 mp3 player, the screen stays on one song. the song doesnt play, and you cant switch songs or do anything at all. i tried taking out the battery and putting it back in, but that didnt work, it still shows up with the same song stuck on there when i turn it on. i also tried plugging it into the computer, and that didnt work either. any ideas?
  • 5 more comments
  • Anonymous Nov 03, 2007
    frozen screen
  • cassia Nov 22, 2007
    Hi~
    My MP3 is also frozen! I tried your solution (put it in the "hold" section and plug it into the computer, but nothing hapened. Anything suggestions??
  • Thegame991 Nov 25, 2007
    I was listenign to a song i always listen too... i turn off my mp3, when i turn it back on it just has a still screen... I CANT PRESS OR DO ANYTHING... it was just frozen... ANY suggestions?
  • Anonymous Dec 11, 2007
    my player do the same thing, when i turn it on the screen freeze.
    HELP ME!!!!!!
  • K-mann Dec 17, 2007
    Same for my Sansa C140. Frozen screen - nothing works. Help!
    K-man
  • jamnj Apr 23, 2008
    i have a frozen screen stays on same song but doesn't play what do i do to fix the problem?
  • jkwchan Apr 24, 2008
        The screen turns on and it is stuck on one song which doesn't even play anymore.
        None of the buttons work; you can't forward to the next song or go back.
        I have tried shutting it down and that won't work anymore. In order to shut it down, I have to remove the battery.
        I have also tried connecting it to the computer. I also tried putting the player on HOLD and then turning it on and connecting it to the computer. Nothing has worked for me so far. Please help!
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 06, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
3895
Points
8
Recovery mode. slide the hold switxh so that is is redish hold record keep holding record and plug into computer.
2 Related Answers
Anonymous
  • Posted on Feb 01, 2008
SOURCE: sansa c140 screen frozen
Have a sandisk 1 GB MP3 player that keeps showing SANDISK at startup. Wasn't able to shut it down.
By pressing volume + toegether with center select, I managed to shut it down. Now it works fine again. Thank you for the tip!!!!
Jean Sintulaire
  • 759 Answers
  • Posted on Apr 07, 2008
SOURCE: SanDisk Sansa c140 MP3 stuck at one song - please help!!
You might have to hold the power button down for like 20-25 seconds and if that doesnt work what I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
3helpful
My Sansa C140 won't work!
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Thank you
Computerrep
2answers
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
SanDisk Sansa e260 MP3 Player
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it doesn't then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
2answers
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
2answers
Frozen MP3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
2answers
NoSpaceForDB Please Delete MoreThan4.0MB
hmmm i'm not familiar with the problem but try this.
First open your mp3 player and go to settings. Under the USB menu change it to MSC. Then plug in the mp3 player to the computer. Open the My Computer on your desktop, right click on the Sansa mp3 player and click Format. Make sure Fat32 is checked and Quick format is UNchecked. Then format the mp3 player. After that it should be clean and work just like a USB drive.
Let me know if this helps!
MP3 HOW DO I PUT SONGS ON IT
first of all, find yourself a good music download site, limewire.com is excellent. then download all of your favorite songs. go to library click on "explore". when the share folder comes up click on "organize" then "select all". when the little pages turn blue right click one of them and then left click "add to windows media player". the media player will come on playing your first song (normal). click on "sync" then click "sync now playing". you can check progress by going to the media library and clicking on the sansa c140 in the sidebar. hopefully you will be jamming before long. oh! do not unplug your device until it says it's ok on the media player or you click stop sync.;)
Help!
Well, i'm having problems with my Sansa c140 also, but with this problem I think I can help, hook your mp3 player into your computer, than delete all the songs, and simply put them all back on, and if that doesn't work, than repost.
Frozen screen and won't play
could be your battery check that.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
