SOURCE: How do I change the transmission in a speed queen
http://docs.google.com/viewer?a=v&q=cache:vaSKIsbofmAJ:www.appliancepartscompany.com/apcocatalog/speedqueen/01-16speedqueen.pdf+change+transmission+in+speed+queen&hl=en&gl=us&pid=bl&srcid=ADGEESj7EkDCJJCpg2i9SS_9xB5sxQYCPAu03NMl-k09R4eea8Iz9JPec08BOsjyCYHJLazuAU0lVuxo9-fK5264w27_vjM76tKi4oTpo4wdGb7Hx-WysRTU_RlxPDeEdxy3hHIkk3yo&sig=AHIEtbS9byLtJXCiotxSA-LOYWSRQ9gi6w
here is a breakdown diagram if you need it.
Step 1 Cut off all power to the machine
Step 2 Turn off water supply
Step 3 - Drain Line
If removing the drain and water lines provide more access to replacing the washing machine transmission, go ahead and remove it.
Step 4 - Water
Turn off the water supply knob. In case you cannot find it then turn off the water supply lines till the job is completed.
Step 5 - Control Panel
Take off the screws at the front end of the control panel. Use a screwdriver. Once the screws are removed, pull out the console and flip it free.
Step 6 - Unplug the Wires
Locate the wires that act as harness. You need to unplug these wires. Use a flat ended blade to push the clips that hold the wires in place. This will release the wires.
Step 7 - Cabinet
The next step in the washing machine transmission replacement process is, to lift up the lid and pull out the cabinet from the washing machine by tilting the machine towards you.
Step 8 - Screws
After you remove the cabinet you will find an agitator cap. Below the cap are screws and bolts which are protected by a plastic cover. Unscrew the bolts and the screw to remove the agitator. This will reveal the shaft where the transmission is located.
Step 9 - Pump
Remove the spring clips that hold the pump in place. Remove the two additional screws on the motor as well. There is no need to remove the hoses.
Step 10 - Freeing the Unit
With the help of a flat tip screwdriver, take off the clip at the bottom. Make sure the motor doesn't fall off. Releasing the clip at the top will free the motor and the coupling from the washing machine transmission unit.
Step 11 - Installation
Free the washing machine transmission from the frame. Make sure to remove the two bolts. Tilt and slide the unit at the bottom. Make sure not to damage any washers in the process.
Step 12 - Final Step
After removing the old, place the new washing machine transmission in place by following the steps above in reverse order. Reconnect all the pipes and fitting. urn on the power supply, open the water supply and test the machine
SOURCE: I have a Speed Queen top loader(older model). It
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
SOURCE: Which top load Speed Queen
I think that you might be able to have an answer from the manufacturer.
Try its web site to see ;-0)
Hope this helps and good luck.
John C
