Question about Lexmark X736de Color Laser Mfp Ms00301
956.02 ERROR. Processor Fan Stalled - Lexmark X736de Color Laser Mfp Ms00301
System fan error
If you have replaced the fan and you are still getting a "Fan Error" then you have replaced the wrong fan. The system fan is not fitted to the top of the processor, it is usually fitted to the case.
Sep 08, 2013 | HP Pavilion m8120n PC Desktop
Fan error
This is an indication that a printer fan has stalled. Check the cable connections at J7 on the system board and at the main fan assembly. The main fan runs continuously when the printer is powered on unless the printer is in the Power Saver mode.
Dec 22, 2012 | Lexmark T630 Laser Printer
What is the processor fan speed for Dell Vostro A860?
This could be the result of to much dirt build up in the heat sink ports blocking vital air flow. Buy a can of compressed air and blow it on fan any open ports, this should prove if the fans the issue, the speed should slow down because of increase air flow cooling the laptop. If this works the machine should be taken apart for better clean out.
Mar 06, 2012 | Dell Vostro A860 Notebook
Processor fan and case cooling fan run for about 10 seconds then shut down. The power supply fan and light stay on but the screen stays black. I don't get any error beeps. I think that its the...
Hi
Please check the Processor must fit or not may this problem is With processor only and also check if processor gum is working or not
Thank u
Harsha
Aug 31, 2011 | Computers & Internet
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | IBM NetVista PC Desktop
When i press the on button, the first logo screeen comes in abt 7-10 secs then after 3-5 secs fan error appears on a blank screen and after another 2-3 secs it shuts down by itself. I cannot boot...
the problem is simple. you need to first change the fan for the processor. The pc goes off since the fan to cool the processor is faulty.........just to prevent damage to the processor. get a correct model, normally by checking the spare part number on the fan and try googling it up on the net. need me know if you need assistance in buying one.
good luck.
Apr 03, 2011 | Computers & Internet
CPU Over Temperature Error
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | ASUS P5PE-VM Motherboard
Dell Poweredge 840 shutdown automatically
Hello
Hope this helps
Jan 31, 2011 | Dell PowerEdge 840 (becwmk1_2) Server
Processor fan
Maybe you have not put the correct fan on and it has shut down to protect itself. Processors overhead catastrophically in a matter of seconds. Also did you connect the fan to a power supply on the motherboard.
Mar 18, 2008 | Intel (SL5TL) Pentium 4, 2 GHz Processor
Lexmark X736de Color Laser Mfp Ms00301 Logo
949 people viewed this question
Top Lexmark Computers & Internet Experts
Duncan Mutch
Shawn DuRee
ray gallant
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
