Bosch Classixx WFC 2465 Front Load Washer Logo
M
Mark Posted on Oct 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Oct 18, 2013
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180350
Points
743
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
5 Related Answers
Anonymous
  • 159 Answers
  • Posted on Aug 04, 2007
SOURCE: Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Anonymous
  • 236 Answers
  • Posted on Aug 23, 2008
SOURCE: Bosch wfr2460
after ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Anonymous
  • 1239 Answers
  • Posted on Sep 13, 2008
SOURCE: bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
prem mathew
  • 662 Answers
  • Posted on Jun 15, 2010
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Anonymous
  • 6277 Answers
  • Posted on Mar 07, 2011
SOURCE: wfr2460 bosch washer drum not spinning.washer
This sounds very much like the belt is broken or, at worst, the motor is malfunctioning. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had.
Hope this is your problem solved.
Good luck,
John C
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Wfr2460 bosch washer drum not spinning.washer displays wash rinse,and spin cycles but no movement.
Good luck,
John C
Leaking drain pump
Yes its very semple takes about 20min.
2helpful
Bosch wfr2460
3helpful
2answers
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
1helpful
2answers
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Bosch wfr2460
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Bosch WFR2460 Leaks
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
