Question about Arris Touchstone Telephony Cable Modem Tm602g/115
I need the value for the network address property.
  • Lamar Fronheiser Oct 17, 2013
    This is for a problem with my Arris Touchstone Device (Cable Modem) Model Tm602g/115 not for my house?
  • 2,113 Answers
Http://www.speedguide.net/routers/arris-touchstone-tm602g-voip-gateway-557
Posted on Oct 17, 2013
  • mikadot
    mikadot Oct 17, 2013
    I'm not sure if you were asking for the ip address to set up the modem or not. Perhaps clarify you question.
    That's exactly what I'm looking for. Thank you!
6ya staff
SOURCE:
I changed internet providers and now my wirless printer doesn't work
STEP1: Print "Network Configuration Page"
  • Make sure paper is loaded.
  • Push the Setup Button on the all-In-one.
  • Use the Down Arrow key to highlight the Network menu.Push Ok
  • Push Ok again to select View Network Settings .
  • Push Ok again to select Print Network Configuration page .
  • A network configuration page will print.
STEP 2: Check the Printer Connectivity
  • From the printed Network configuration page, note down the printer IP address, (example : 192.168.1.6).
  • Click start, and then click "RUN".
  • In the RUN box, type "CMD" press OK.
  • In the command screen, type "Ping IP address" (Example: Ping 192.168.1.6). Hit Enter.
  • You must get output similar to below.
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=1ms TTL=64
Reply from 192.168.1.6: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.6:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
STEP 3: Configure Port.
  • Click on start >> Control Panel >> Printers and Faxes.
  • Right click on printer icon, select "Properties".
  • Click the PORTS tab on the top.
  • Select your product under the Printer column, and then click Configure Port . The Configure Standard TCP/IP Port Monitor dialog box opens.
  • Look in the Printer Name or IP Address box. This value should match either the MAC or IP Address on your network configuration page. If the values match delete the printer and install it again.
  • If the values does not match,Click inside the Printer Name or IP Address box, and then type the appropriate value (IP address / MAC address) as listed in network config page.
  • Click OK , and then try printing again.
Regards
Riztech
Mar 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Tip
How to fix the Windows 7 Network Connection Problem
On this short demonstration, I would like to present, how to fix the network connection problem in windows 7. As we know, many Windows 7 users are facing Network connection problem like;
"unidentified network" or "no internet access"
I don't mean this will work for all the users, but most users will definitely get benefit from this. There might be other fixes too, but I am only presenting the most common and the simplest method.
Before we begin, please disable the Internet Protocol Version 6"ipv6" (what we commonly use is Internet protocol version 4 "Ipv4") from your "Local Area Network Properties" if you don't need it (this is not totally implemented for home users, if you are sure you need it, no problem just leave it as it was). To do this, click on the "Local Area Network Status" click "Properties" and from the list below the "General" tab, uncheck (remove the tick mark) from the "Internet Protocol (Tcp/Ipv6)" or something like that, and click "Ok" and close it.
Also enable "dhcp" services, if otherwise you'll need to provide a static ip address, type in the ip address which was given by the Internet Service Provider (ISP) on the IP address box. This depends on the service provider from whom you get your connection. When you are done, click "Apply" and then "ok".
Now, let's proceed simply like this.
Start -> Run (in the text box)-> and type in "msconfig" (without qoutes)
The System Configuration Utility window will pop up, now click on the "Services" tab and from the services lists, locate "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762", and disable it. (Remove the tick mark on the left hand side of the above mentioned "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762" )
Click "Apply" and then "Ok". You'll need to restart your system for the changes to take effect.
Optional; You can also go to the "services" directly by typing "services.msc" in the run box. The only difference is that, you'll need to right click on the "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762", sand select "disable" or "Stop". Restart your computer or you can try disabling and enabling the Network Adaptor. Now check your internet connection by dialing using your username and password or try connecting to the ISP.
If unfortunate, this doesn't work for you, you can also try the following methods;
Open the Network Adaptor Properties, click on the "configure" and then again "Advanced" and on the left pane, click "flow control" you'll see the value (which is set) on the right hand side of the dialog box, change the value to "rx & tx" (when you click over the value box, a drop down list will be displayed, select rx&tx from the list and click ok). Sometimes even small trick fixes the problem.
If anyone has come across this similar problem and have solved using another method, it'd be very much appreciated if he/she can add them as comments. Good luck to you all.
on Jun 16, 2010 | Computers & Internet
I have wildblue and my connection will not consistently connect . It freezes up the computer running xp wireless router is WNR854T
With wireless connections, there are at times brief disconnects. If you set your computer's ip address to a fixed value, this may help the problem. With a DHCP connection (not fixed) you could be getting a different address after one of the temporary disconnects causing the hang. Go to control panel, network connections, properties, then scroll down the window to the tcp/ip line , highlight it, then click the properties button. In the properties, click the use ip address button, enter a fixed ip address. If you are using a standard home address system, use 192.168.1.10 (if you have more than one computer, make sure each address is unique). subnet mask is 255.255.255.0, gateway is your router ip address, typically 192.168.1.1. Check your router information to be sure. You can use your router ip for the DNS server ip. If that does not work, check the DNS address provided in your router settings. Save all the settings.
See how that works, if it works, please leave feedback.
Good Luck
Feb 13, 2010 | Computers & Internet
How do you find out your routers IP adress
go 2 control panel and click network connection. then go to local area connection and click right mouse and see properties select tcp/ip address and click properties. then u will see ur ip address
Aug 03, 2009 | Computers & Internet
I have trouble browsing the internet. I often get this message: Internet Explorer cannot display the webpage
You might be having a DNS problem. DNS (Domain name system) is responsible for changing the website name to the address (where the website is stored). You can try openDNS (www.opendns.com) The site can be confusing so here are the instructions. 1. Go to control panel > network connections 2. Choose the connection that gives you internet, right click on it and Click properties 3. Now select Internet Protocol (TCP/IP) and click properties 4. Check the box that says "Use the following DNS addresses" 5. Enter the following values (addresses) 208.67.222.222 208.67.220.220
Jun 03, 2009 | Dell Vostro 200 Desktop Computer
Connection keeps intermittently dropping.
Connect with an ethernet cable and find out the IP Address,
subnet mask, gateway, and dns,
by double clicking on Local Area Connection, click support, click details.
Enter these values for the wireless area connection
To set the values do the following:-
start -- > control panel --> network connections
right click on wireless area connection select properties
click on TCP/IP and press properties
Set to use the following ip address
enter the values from wired connection
ignore any duplicate warning messages
Thiswill resolve the issue, I have used it many times.
Jan 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless linksys wrt54gs router
I have fixed this problem many times by entering just the gateway in the TCP/IP properties or all values as static e.g ip address, subnet mask and gateway as follows:-
Limited Connectivity | wireless network
Also note the Subnet Mask, Gateway, and Primary and Alternate DNS values
To get these :-
1. Double click on Local Area Connection under Control Panel --> "Network Connections"
2. Click "Support" --> Click "details"
Enter these values for the wireless area connection like this :-
1. Click "Start" -- > "Control Panel" --> "Network Connections"
2. Right click on "Wireless Area Connection" --> select "Properties"
3. Click on "TCP/IP" (in th middle box) -- > Click "Properties"
4. Click "To use the following ip address"
5. Enter the values you got from wired connection above
6. If you get any duplicate warning messages ignore these
This will resolve the issue, I have used it many times
Jan 10, 2009 | Linksys Wireless-G WRT54GS Router...
Upgrading the motherboard
There is no way to change the MAC address, but you can make Windows tell the system it has a different address that might fool your other program. Follow the instructions below.
Change the MAC address in Windows
  1. Go to Start -> Control Panel. Double click on Network Connections (inside Network and Internet Connections category in Windows XP). The, right click on the active network connection with network adapter that you want to change the MAC address (normally Local Area Network or Wireless Network Connection) and click on Properties. Above steps work in Windows XP, Windows 2000 and Windows Server 2003 . For Windows Vista, access to NIC’s properties is from Control Panel -> Network and Internet -> Network and Sharing Center -> Manage Network Connections.
    Alternatively, if you already know which network adapter that’s responsible for your network or Internet connection, go to Device Manager and open the properties dialog by double click on the NIC itself.
  2. In the General tab, click on the Configure button.
  3. Click on Advanced tab.
  4. In the Property section, select and highlight Network Address or Locally Administered Address.
  5. To the right, “Not Present” radio button is by default selected as value. Change the value by clicking on radio button for Value:, and then type in a new MAC address to assign to the NIC. change-mac-address.jpg The MAC address consists of 6 pairs of numbers (0 - 9) and characters (A - F) combination. For example, 88-17-E8-90-E2-0A. When entering the new MAC value, omit the dash (-), for example 8817E890E20A.
  6. Click OK when done.
  7. To verify the change of MAC address, go to command prompt, then type in one of the following commands: ipconfig /all
    net config rdr
  8. Reboot the computer if successful to make the change effective.
Dec 18, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I get an IP conflict error message.
Dear you havent mentioned that you are on wireless or on Lan.
any way... issue is that your both systems have the same ip addresses and now you have to change ip address of any one of them..
i recommend you to change ip address of your desktop computer.
here is the way to change it...
  1. Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
  2. Right-click the network connection that is connected to the private ICS network, and then click Properties.
  3. On the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties.
  4. On the General tab, click Use the following IP address. Configure the entries as follows: (if the option is selected that "obtain the ip automaticaly" then leave dont follow the given instructions and msg me again)
    • IP Address: . just change the last value of your ip address. say its 192.168.1.20 .. change the last value to any other two digit value..
    leave the other configurations as it is.
  5. Click OK.
  6. Click Ok
Now try it..
Rate me if you think it helps you..
best regards,
Tanveer Ahmad Khan
Dec 14, 2008 | Computers & Internet
How do i put in the mac number
  1. Go to Start >>> Control Panel and double click on Network Connections.
  2. Right click on the Network Connection you want to change.
  3. Under “General” tab, click on the “Configure” button
  4. Click on “Advanced” tab
  5. Under “Property section”, you should see an item called “Network Address”
  6. On the right side, under “Value”, type in the New MAC address you want to assign to your NIC.
  7. Reboot
Sep 29, 2008 | Belkin Computers & Internet
Arris Touchstone Telephony Cable Modem Tm602g/115 Logo
178 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
