Computers & Internet Logo
Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power switch,reset switch,power led connections to motherboard?
Diagram,how to connect power switch,led,reset switch to MSI MS 7548 (aspen) Motherboard?
Mark Taylor
Level 3:
  • Master 728 Answers
  • Posted on Apr 25, 2009
Mark Taylor
Master
Level 3:
Answers
728
Questions
0
Helped
335394
Points
2225
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Anonymous
Level 2:
  • Expert 86 Answers
Anonymous
Expert
Level 2:
Answers
86
Questions
0
Helped
43428
Points
201
MSI's website provides extensive board manuals in PDF form which show all switch and connectors
2answers
How to connect power switch,led,reset switch to MSI MS 7071 Motherboard?
They connect to the JFP1 connectors on the lower right edge of the board. The power LED connects to the 2 and 4 pins, The HDD LED to the 1 and 4 pins, the reset to the 5 and 7 pins and the power switch to the 6 and 8 pins. The pins are numbered up down right to left like this.
97531
08642
tip
How to connect power switch,led,reset switch to MSI MS 7548 (aspen) Motherboard...
MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup slightly differnent, but your JFP1 should be in the right hand corner all by itself.
I'm attaching a diagram of the layout of a similiar board
Good Luck Everyone!!
on Apr 02, 2010 • Computers & Internet
How do i connect the power leds of msi ms 7071
97531
08642
2helpful
2answers
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
How to connect power switch on msi ms6787
At the bottom right hand corner of the mobo you'll find there is a set of pins marked JFP 1 and the power switch pins are marked clearly so are the HDD Led, reset, Power Led etc. Plug in your wires which are also marked, corresponding to the marked pins.
3helpful
I need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link. http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=558
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Mike
1helpful
2answers
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Grand Canyon Tech
Grand Canyon Tech
