First you need your 4D software installed on your computer (or which ever version you are using). Insert the DVD into your drive. Then open your embroidery program and then click File and Open. When the new window opens, search for your DVD drive then find the embroidery you want and click Open. The embroidery yoiu chose should open in your embroidery program with the hoop displayed on the screen. Then save the embroidery under a new name in your embroidery design folder on your computer. Then insert your USB into your computer, Open Disk Manager and Read your USB. Then click on one of the empty squares and then click File then Open. In the new window find the embroidery file you saved under a new name on your computer and choose it. It should show up in the empty square you clicked on. Then Write to your USB. Now you are ready to move your USB to your machine and the embroidery should be there. Hope this helps. Good luck.
SOURCE: Husqvarna Designer 1 manual
We sell the manual you are looking for:
http://sewingpartsonline.com/viking-designer-1-sewing-machine-instruction-manual.aspx
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
SOURCE: husqvarna designer 1 floppy drive to usb
First you need the USB upgrade kit that has the connectors and parts to change the cover of the machine.
Next, you will need a new main circuit board if your machine was made prior to about 2006.
At this point, the cost of parts is about $489. If you can get someone to install these for $10, you can get this done for under $500.
Otherwise, go to an authorized Husqvarna Viking dealer and check into trading your Designer 1 in for a Designer SE. You will then be able to plug in an external 3.5 floppy drive to read your old disks, a USB stick, or plug directly into your computer and read them from the hard drive (an upgraded Designer 1 can read ONLY from the stick). Used Designer SE's are very reasonably priced since the introduction of the Designer Diamond as the new top of the line and you may be able to get a full manufacturers warranty on the gently used machine.
