LG VX8300 Cellular Phone Logo
A
Anonymous Posted on Oct 16, 2013
Where is the sim card on a LG VN150 located - LG VX8300 Cellular Phone
3 Related Answers
A
Anonymous
  • Posted on Jul 24, 2008
SOURCE: sim card slot location
it doesn't have one. Only a Groupe Spécial Mobile (GSM) phone has them. The vx5200 is a Code Division Multiple Access (CDMA) phone.
Anonymous
  • 6 Answers
  • Posted on Dec 19, 2008
SOURCE: SIM card location
The Chocolate phones do not have sim cards.
Anonymous
  • 221 Answers
  • Posted on Jan 05, 2009
SOURCE: Lg enV vx9900 Sim Card Location
the LG enV is a CDMA phone, so you cannot use sim cards in it
How do I get contacts from a LG vn150 with a broken screen?if there is no sim card
fix the screen
or google usually does automatic sync of contacts
or try contacting a soft. tech. they are not expensive. ( don't recomend downloading any software (90% chance you will get viruses and get issues with your pc too)
1helpful
I need a user's manual for LG revereVN150 cell phone
or go google and type in--user manual for lg revere cell phone model vn150--- and there will be a pdf version down load
it may even have the web site mentioned
HOW DO I TRANSFER PHOTOS FROM MY LG VN150 TO MY PC
To transfer photos from your LG phone to pc, usually you need to conntact your LG phone to pc in MTP mode first. Then we can use Android data manager to help us transfer photos to pc directly. https://www.coolmuster.com/android/transfer-photos-from-lg-to-computer.html
Default unlock code for LG Revere
i need an unlock code on my lg vn150 i forgot my code
Cell phone contacts
Step 1Remove the SIM card from your Motorola phone. The SIM card is a small chip that is located under the battery in your cell phone. After you've removed the SIM card from your Motorola phone, remove the SIM card from your LG phone.
Step 2Insert the SIM card from your LG phone into your Motorola phone. Turn on the Motorola phone.
Step 3Press the "Menu" key and select the "Address Book" option.
Step 4Select "Options" by pressing the right soft key. The "Select Multiple to" option will appear on the screen. Choose the "Select Multiple To" option and then select "Copy to SIM to Phone."
Step 5Remove the SIM card that you placed in your Motorola phone and insert it in your LG phone. After inserting the SIM card, turn on your LG phone.
Step 6Click the "Menu" key on your LG phone and select the "Address Book" option.
Step 7Select "Options" and choose the "SIM Management" option.
Step 8Select the "Copy from SIM" option and choose "Select All."
Step 9Select the "Copy" option. Your contacts will be transferred from your SIM card to your LG phone.
Where is my sim card located in the alltel lg ax8575 touch?
LG AX8575 is a CDMA phone by Alltel. CDMA technology does not uses a SIM so there is no place for SIM card.
3helpful
SIM card location
2answers
Cell phone sim card
All mobiles have a sim card and are normally located under the battery.
Take the back of your phone, remove the battery and it should be there. Sim cards are normally a small oblong piece of plastic with a corner cut off. The flip side of one will have a metal strip, which is your sim memory. Don't damamge this side of the sim otherwise your card will be useless.
Hope this helps?
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
