SOURCE: I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
SOURCE: Craftsman 25cc Convertible weed wacker
Yes, a simple carburetor cleaning will do the trick. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen is free from debris. Clean the small portals with a Den Tek Brush (http://www.dentek.com/shop.php?target=products&product_id=7). They work great for this job. Reassemble and start.
If this doesn't do it, buy a new carb. kit and replace all appropriate parts.
Jim
SOURCE: Hve a Craftsman Weed Wacker 24 cc Need to find out
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
SOURCE: I need a replacement head for my 25cc crafstman
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
