Lexmark X7170 All-In-One InkJet Printer Logo
Karen Platzer Posted on Oct 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother MFC-9320CW is printing blurred images
MrHandyman2
Level 2:
Sergeant:
Habit-Forming:
  • Expert 106 Answers
  • Posted on Jan 19, 2016
MrHandyman2
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
106
Questions
0
Helped
66058
Points
605
Its probably due to your software or low resolution images. Brother mfc 9320cw manual Download Free Manuals
COMPUTER Generation
Level 2:
  • Expert 88 Answers
  • Posted on Nov 23, 2013
COMPUTER Generation
Expert
Level 2:
Answers
88
Questions
Helped
25346
Points
133
Click menu once and OK 3 times and reply the status of the test print
What are brother printers that take tn210 cartridges
Brother color machines use it:
Brother DCP Series: DCP-9010CN,
Brother HL Series: HL-3040CN, HL-3045CN, HL-3070CW, HL-3075CW,
Brother MFC Series: MFC-9010CN, MFC-9120CN, MFC-9125CN, MFC-9320CN, MFC-9320CW, MFC-9325CW
BR
Brother MFC-9320cw printer has stopped printing because it is at 50,000 sheets fed & says it needs to 'Replace PF (print feed) kit'. It was feeding just fine. Brother says I have to go to an aut
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
2answers
2answers
Scan problem
What is it scaner or paper problem?
If it is a paper problem take out all of the paper and return few pages in the tray. Try and print out something.
But I still thing that you will have trouble.
If the things I tell you don\'t wotk you may have to change a spear part like drum unit or a toner cartridge.
Sometimes if the drum unit is at it\'s life end you may experiance this problem.
2answers
Need to know how to replace my cartridge
Replacing the toner cartridge is an easy task.
Check out this link and replace your toner cartridges by yourself.
10helpful
3answers
We have a Brother mfc-9320cw printer that is printing with a thick and ugly crust of ink on the right edge of every 8.5x11" sheet we print. What is causing this? We've replaced the belt. It...
This happened to mine, only my thick edge was blue. My problem was that the little green slider that cleans the wire on the toner holder was pushed to the wrong side. (Sorry, can't remember technical term for the green thing or the wire! It has an arrow on it and it's pretty easy to spot.) Push it all the way back to the left until it clicks and it should fix the problem.
My brother MFC-9320CW say's its connected but when I attempt to print, it says Printer is Offline. What should I do?
I have this problem also with my Brother MFC-490CW printer. I find that I have to shut the printer off, then turn it back on to re-establish a connection.
3helpful
2answers
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
