What size breaker and wire do i use and the plug is not conventional type is small but one spade is horizontal
The plug type is a clue to voltage and current. Usually by law (electrical code) a normal plug with one vertical blade and one horizontal blade is 120 volt 20 amp. If you read the name plate to see the voltage and current required and it is the wrong plug type then it could accidentally be plugged into the wrong voltage if you were in an unfamiliar commercial building for example. So the plug type should match your specs. If this is just for you and your own specialized cables then make sure that the plug can handle the current specified or upgrade it to a safer plug style. I can't tell you a breaker and wire size etc until you give me the name plate specs.
