Your waste toner bottle is full. Needs to be replaced or emptied. I believe the bottle is located in an area that requires tools to remove it. If your machine is under maintanence you should call them to have it replaced. If not then you will need to empty it yourself. Be careful, take bottle out and wrap bag around the opening and turn upside down until all powder is out. then clean off and replace. Turn off machine and back on error should clear.
Hope this helps,
TankMurdock
reset and clear code by press face 28 enter and go to clear code
