I used my Toshiba Laptop all day yesterday with no problem. Shut it down as usual around 4:30pm, tried to restart around 8:30pm. Lights on front came on, but it appears to be stuck in sleep mode. Tried removing batter and ac adapter and replacing, but screen, num/loc key, and caps lock key do not activate. Any suggestions? This is a Toshiba Satellite L555D-S7005 purchased 4/30/2010.
Here are a few things to try.
First is a method to reset the laptop with the battery out and the adapter plugged in.
How to Reset an HP Laptop by Holding Down the Power Button With the...
Secondly, you might plug in a 2nd keyboard. If it works, you know the problem is in the keyboard and not the software.
Thirdly (and a long shot), take the battery out, wait 60 seconds, put the battery back in. Then, press the power button, F8, and the shift key at the same time.
Fourthly, Remove battery, unplug power, hold power button for 60 seconds, turn on computer with power plug only, then shutdown, add battery and restart.
Fifth, Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
If none of these work, perhaps there is a short in the keyboard.
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
SOURCE: My satellite M55-S331 Toshiba laptop screen went black
cheap soma[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20soma%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]cheap soma[/url] zoloft and pregnancy[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20zoloft%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]zoloft and pregnancy[/url] ultram[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20ultram%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]ultram[/url]
SOURCE: VAIO Notebook VGN-FS742/W is not booting
sorry to let you know sounds like hard drive is shot.........
SOURCE: Computer was in hibernate or
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
