The computer is booting up the usb drives before the main drive causing the computer to freeze up when a memory card or external hard drive is attached
Hi apicard91
Go into your BIOS and check your boot sequence or boot menu.
there should be a option to disable booting form either a "removable device or external device or usb device"
Just disable that option and then you good...
Please rate the service you recieved
When you boot the computer a message will come on the screen indicating what key to press in order to get into 'setup'.
Once you are in setup, you want to go through it until you find entries dealing with 'boot order'. What you want to do is set it so that it does not try to boot usb devices before it tries to boot from your hard drive. That'll do it.
Disable legacy USB, yes.
What you want to find is boot order. Personally I usually set it to boot from cd first, then hard drive.
The problem you are having is that the system is trying to boot from your removable drive before it tries to boot from your hard drive. You want to change the order of boot devices the system looks for so it finds your hard drive before it looks for your removable drive.
if you don't want that feature, you can go into the bios , most likely the boot up sequence, and not have usb devices boot.
thank you
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
I can not find the usb under the bios, the only thing that looks like i could change is the legacy for the usb do i disable this
