Mywinlocker com Hello. again, I accidentally deleted my winlocker suite. Did an Acer recovery management to reinstall but there is no icon in the system tray. Having messed around a bit, I found the icn and installed it on the desktop. double clicking opned the ico in the system tray but the tool does not respond to setting up password.What now? [email protected]
SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
SOURCE: Acer Aspire 5720-6438 recovery cd/driver cd
if you need drivers, you can download it from www.acerpanam.com.
for recovery cd, i don't think acer have it online, you need to order it from them.
FYI, if you haven't delete the partition in your hdd, you can use alt+f10 to re-install your Operating system and after that, you can create your own recovery cd.
SOURCE: Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
SOURCE: Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
SOURCE: crystal eye webcam for acer aspire 6920G says camera not found
hey, I had the same problem, I've got an Acer Aspire 6920 and I swapped out Vista that was on it for Windows XP
I went to the link you posted but it just goes to acer.com
so I figured I'd try something
if you go to acer aspire 6920 drivers, you can only pick Vista and Windows 7, and not Windows XP
instead, pick 6530 drivers (older acer) and pick the Bison driver:
http://global-download.acer.com/GDFiles/Driver/Camera/CCD_Suyin_2.0.8.3.zip?acerid=633639858186446758&Step1=Notebook&Step2=Aspire&Step3=Aspire%206530&OS=V10&LC=en&BC=Acer&SC=PA_7
Install it (with or without installing the previous Crystal eye, doesn't matter, and it will work properly
