Siemens H 4680 BP KAT Stainless Steel Electric Single Oven Logo
A
Anonymous Posted on Oct 14, 2013
How to reset the clock siemens electric stove
Chris Huff
Level 3:
Top Expert:
  • Siemens Master 6,289 Answers
  • Posted on Oct 31, 2018
Chris Huff
Siemens Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017790
Points
74913
Check your owners manual for instructions
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Oven won't work beacuse of the timer on the stove.
It depends on the make and model and wether it is a digital clock.
But generally if you press/turn the larger knob this will reset the clock and return the oven to manual cooking .
Jan 01, 2010 • Ovens
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
3helpful
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Top Siemens Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Siemens Oven Expert? Answer questions, earn points and help others
