When recording from a phonograph, I use the following items.
Depending on the phonograph whether or not it's MC or MM makes a difference in sound although most can't tell the difference. Also, you need to know if your phonograph requires a pre-pre amp or if that pre-pre amp is built in and the line coming out is at line level. The Rolls item is a pre-pre amp unit which takes to older phonographs signal level to that of input levels which allow the phonograph to be connected to any aux line in.
On the back of the computer, you can plug the RCA jacks from the phonograph into the adapter and directly into your computer via the MIC (usually pink) input. Most of the time this is sufficient. If the volume is too loud, or sounds horrible, chances are you have a pre-pre amp and you then plug it into the line in (usually blue)
First I would connect the RCA's from the phonograph to the adapter and plug it into the mic and see how the sound is.
Keep in mind that you do not use the ROLLs unit when connecting this way. If it's too loud or distorted, plug it into the line in.
For recording, you can download Audacity which is free and a wonderful editing program.
