SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
SOURCE: 80 series kenmore washing machine not spinning in spin cycle
You may either have a broken motor coupler (connects the motor to the transmission) or the clutch/brake assembly is slipping. To test the motor coupler start a cycle, if it fills and agitates, the coupler is ok.
You can check the clutch/brake by selecting the spin cycle, open the lid and press the lid switch down using a pen. When the motor starts check for either a very slow spin or give it a boost by pushing the inner drum clockwise and see if it picks up any speed. If it spins just a little, the clutch/ brake assembly is slipping and will need to be replaced.
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
