Xerox 6R1238 6204 Wide Format Printer Toner Logo
A
Anonymous Posted on Oct 12, 2013
Xerox 6204 stops printing halfway through - Xerox 6R1238 6204 Wide Format Printer Toner
Xerox wide format 6204 error
this is the error to stuck the machine like my machine was stuck and i solve from here quickbooks error 6000 83"}" data-sheets-userformat="{"2":8705,"3":{"1":0},"12":0,"16":12}" style="color: rgb(0, 0, 0); font-size: 12pt; font-family: Arial;">quickbooks error 6000 83
2answers
What is solution error code in xerox 6204 123-314
I am afraid you will have to call out a xerox service tech, he will have to reinstall the M\C siftware.
3helpful
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
1helpful
2helpful
I have a xerox phaser 3124 which have a paper jam every time when i try to print stuffs.. it gets jam halfway and the catridge is new.
Xerox printers have known issues with the rollers. You may want to look into getting some new rollers, they're not that expensive. I think with this model there's one in the tray, and one up above where the paper enters the printer.
Xerox 8500 - overprinting when double-sided
That normally is caused by a dirty maintenance kit. Often times they dry out and do not put enough lubricant on the drum, I would start with a new mainteanace lit., you may also have a bad wiper blade, although thats less likely.
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
6125N won't print in network
If you can address the printer through CentreWare then your halfway there. Is now possible to print a test print via CentreWare if that works look at your p.c, driver setup.
Good luck.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
