Question about Sony CRX Computers & Internet
Sony MHC-vx888 turn volume up sound disconnect says push power to protect
  • Sony Master
  • 4,057 Answers
The capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
Posted on Oct 20, 2013
6ya staff
SOURCE:
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
My sony mhc-s9d goes to 'push system protect;
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 18, 2011 | Sony Audio Players & Recorders
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Dec 19, 2008 | Sony MHC-RG30T Shelf System
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
Computers & Internet Logo
130 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
