Ive had the miver for about a month, i have it connected to my stero when I use my cd players i have no sound coming from my left speaker I know itss not the stero cause when iI use it on radio tboth speakers work fine. Can anyone tell me if I ble a channel or a fuse or anything? any help will be greately appreciated! Im a beginner so I dont even know where to begin troubleshooting. thank you
When you said radio I am thinking you mean receiver when you say stereo. Have you tried using your CD into the input that you are plugging your mixer into? If you get both sides , right and left of your CD then it is a problem with the signal from the mixer and we can work from there.
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Ive checked all the cables..I just got new ones and the same problem.I get sound in my headphones from the right side but not the left.
I have tried that I spent half the day messing with everything and I still have the same problem. Frustration has kicked in! Im almost to the point of breaking down and just buying a new mixer. I do appreciate all the info it was a help-thank you:)
Same problem (input 4 and 2, phono) no left channel-def the mixer. Ideas?
Are you getting both channels at your boards headphone output jack?
