Somehow my tv got stuck in that burn test mode and wont respond to remote and only shows a blank screen that changes colors every 10 seconds.i was trying to work the remote for my dvd player and it ended up changing the tv to that factory setting mode.i have not been albe to get any response from the tv yet.new batteries in the remote and everything.
SOURCE: Sony KDL 46V2500
This set does have a video problem. If it was bought locally, then, the retailer may have a 30 day return policy. If bought online or cannot be returned, then, contact Sony, for a service center in your location: http://eservice.sony.com/webrma/web/index.do Either way the set is to new to have a problem and you should get it resolved as soon as possible.
SOURCE: Can't Change Inputs on TV
make sure that your remote is on the tv cotrle mode rather than the dvd control mode
SOURCE: I cannot switch my TV mode to video mode
Hi, all you have to do is go past Channel 2 and the screen on t.v. will say Line that is where you will watch all your DVD movies...
Good Luck as I had the same problem when I first hooked up the dvd player to the t.v. , I thought I was going crazy , turned out it was simple... Enjoy ...
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
SOURCE: Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
