Horace if you have an ohv engine, remove the hood to access the valve cover. remove the 4 bolts and be very carful not to break the gasket. roll the engine until the rockers feel loose. If you call the mower repair shop they will give you the measurements, i think they are ext. 0.07 int. 0.05. but check for sure. LUCK to YA.
Testimonial: "Ron I was really looking for information on a John Deere 310C backhoe. I need to know the procedure for adjusting the valves."
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
