Question about Crown CE1000 2-Channel Amplifier
Without any audio source or speakers on output attached, the Crown CH1 Amplifier (as soon as you put the on/off switch to the ON position, the CLIP light blinks a couple times and the FAULT lights blink until a loud "CLICK" sound is heard and the unit turns off.
    Champion:
    New Friend:
  • Crown Expert
  • 232 Answers
Amp is in fault mode...it has a bad problem...one you could fix if you join the Navy, become a ET, go through Nuclear Power School and pound on a few MouMous....time for a shop or new amp
Posted on Dec 16, 2014
  • Crown Master
  • 5,699 Answers
It's very likely that the main power amp section has a faulty part on it that is presumably causing an overload. You should check the devices on the main heat sink of the amp section.
Posted on Oct 19, 2013
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 31 Answers
SOURCE: CROWN CE 1000
Is it clipping for real or overheating ? It may just be a fault with the indicator light circuitry itself. Make sure the input levels of the amp are matched with the output levels of whatever device is running into the amp, they will either be +4 dbm or -10 dbu, if you have a choice you want them to be set at +4 dbm. Crowns are professional amplifiers and withstand years of hard touring on the road, it would definitely be worth it to take it to a good repair shop if you can't remedy the problem yourself.
Posted on Aug 07, 2008
farr64
Edward Farrell
  • 121 Answers
SOURCE: blinking red fault warning
timy check the speaker conections before condeming the amp
Posted on May 01, 2009
Anonymous
  • 10 Answers
SOURCE: The fault lights are blinking. No audio
If the amp is going into protect without audio passing it could very well be an internal short. In this case audio typically won't pass at line level. Have you tried turning the input gain stage knobs all the way down as well as the source material and slowly creep the volumes up? If it takes some audio before it faults you may want to double check the load you are placing on the amp's outputs. I'm assuming at this point it doesn't matter what speakers you are hooking it up too, it still crashed on you. Remember that Audio can be measured in voltage as well so you can measure the outputs of the amp with a volt-ohm meter.
Posted on Sep 24, 2009
petraman7
Scott Frye
  • 1175 Answers
SOURCE: fault lights keep blinking
I have one upstairs in my repair que. There are some small glass fuses ( 20 mm long) on the power supply board.
Check those
Posted on Apr 23, 2010
Crown amplifier xls402 fault indicator remain on and protection relay is not switching
If you have eliminated any shorted speakers, cables etc, then the only other cause is a shorted device on the power output board. Probably a device on the heatsink.
Oct 03, 2018 | Crown Audio Players & Recorders
How do I work out why there is no sound at all from one of my speakers. I have switched them and it is definitely the speaker
After confirming speaker is not getting the audio, need to work toward the audio output. Your next stop will be the audio output from the power amplifier (if there is one), or if the audio is coming out of the car radio. If audio is at the source output (or amp out), you have a broken wire between the source and the speaker. Bypass this wire to test.
Jan 27, 2015 | Cars & Trucks
My xti 6002 goes to thermal protect after few seconds after i switch it on .The problem is only on ch2 and ch1 is fine.what is causing the problem.
I've been seeing this a lot. The outputs are common failure. Needs to go to a shop. Shorted transistor is likely the cause.
Jan 11, 2014 | Crown XTi 6002 1200w Stereo Power...
On 2001 Crown Vic, radio lights are on, channels change,etc but no audio. Fuse issue or any other possibilities?
sounds like your speakers aren't connected properly. check your speaker leads coming from your radio and make sure they are positive to positive and negative to negative. if you're using an external amplifier,check your RCA cables and your speaker outputs on the amp. make sure thr remote turn on lead is connected, otherwise the amp won't even power on.
hope that helped, good luck
May 31, 2012 | 2001 Ford Crown Victoria
Sony STRDH800 emits a loud humming noise cuming throu speakers as soon i switched on and after 3 minuts av reciver switched off byself and blinking protected......plz help
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Aug 03, 2011 | Sony STR-DH800
I have a 1990 crown vic and the speakers are bad and i need to know what the speaker wire color coding is for the front ad back speakers.
Got this from http://www.modifiedlife.com/1990-ford-crown-victoria-car-stereo-wiring-schematic/ I have used this site before, and the wiring guide was accurate for my grand marquis
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Dec 15, 2010 | 1990 Ford LTD Crown Victoria
Audio routing
either activate something like "treat all outputs as seperate" in your soundcarsd setting software, or, if this is not available, get a second soundcard.
Jun 29, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Left side output
Sounds like there is a short somewhere on the left channel inside the amp. not easy to fix without seeing the unit.
Jun 16, 2009 | Crown CE2000 2-Channel Amplifier
Protection light on Visionik V204XT
What happens if you have the positive 12v wire from the battery connected?
Nov 16, 2008 | Visonik V204XT Car Audio Amplifier
Sound
Hi monmax,
I hope you are aware that in bridged mode your amp will become monaural (single channel, double power). If you still wish to bridge it:
Switch of power.
Set mode switch behind amp to "bridge" position.
Connect speaker positive to CH1+ve terminal of amp output and connect speaker negative to CH2 +ve terminal.
Be aware that now, in bridged mode your amps output power delivery is 1100 watts for a 4 ohm speaker and 900 watts for an 8 ohm speaker. Make sure your speaker can handle that.
Peace
Jango.
Mar 03, 2008 | Crown CE1000 2-Channel Amplifier
Crown CE1000 2-Channel Amplifier Logo
254 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
