Question about D-Link DIR-625 (790069292637) Wireless Router
How to connect a new router d linksys and a soma network
I bought a new router d linksys and a soma network port but i dont know how to connect it together to start working pls i need all the member assistance
And i have another problem pls i want to connect my laptop to unsecure network in my office but anytime and connect it will not responed and i will not connect to net pls help me.
  • ikkenom May 11, 2010
    When in your office, does your laptop detect the name of the "unsecure network"?
    If so, when you try to "connect" to that network, does it connect,
    or what error-message do you get (and how many seconds after clicking CONNECT does it take before an error-message is produced) ?
6ya staff
SOURCE:
Anonymous
SOURCE: DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Posted on Nov 09, 2007
Anonymous
  • 33 Answers
SOURCE: connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Posted on Jan 09, 2009
Anonymous
  • 44 Answers
SOURCE: can not connect to my wireless secured network
Here is the support link for the di624, just so you know this unit is not sold or supported in the US.
http://www.dlink.com.au/tech/
Please let me know if this helps...
Tim
Posted on Mar 26, 2009
Anonymous
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
fougzki
  • 700 Answers
SOURCE: Not able to configure and connect to internet using router
Manually configure the setting in your LAN, this could help.
Connect a LAN cable between LAN1 of your router then to the LAN port of your computer. Power the router.
Goto Lan settings, highlight TCP/IP, then click properties.
In your lan settings manually input IP address 192.168.0.52, Subnet 255.255.255.0, gateway 192.168.0.1
You can input also the DNS number of your IP.
Then open web browser type in the address bar 192.168.0.1. You should go straight thru router utility setup security log in.
This can also be set wirelessly. Leave comments if I miss something.
Posted on May 18, 2009
I dont know where the end of the blue cord goes
Hi !
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Thanks.
Mongkey
"Understanding explains better..."
Jan 21, 2011 | Linksys WRT160N Wireless Router
Have Linksys Wireless-G 2.4 GHZ 54Mbps Broadband router. Bought a new desk top computer and it won't let me install the CD. Linksys tech support was unable to assist because the warranty had expired. I was...
Hi there, you don't need to install from the disk. Make sure your modem connects to your router and then the computer's LAN port is connected to the LAN port of the router. Open internet explorer and in the address line type 192.168.1.1 this will connect you to the router's setup. On older Linksys routers the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." You then can find the wireless setup to configure your router. Make sure if you use a WEP code you use the same code from your computer's wireless adaptor. Good Luck...
Nov 12, 2009 | Linksys Wireless-G Broadband Router
I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Oct 28, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
Connecting xbox 360 live
if you plug the computer into the usb port a box will come up and you register it as for the adapter get the one for the xbox plug it in and go to the dashboard then console setting then xbox live connection then test connection and if it doesnt work try the linksys one or the wired one.
Jul 12, 2009 | Microsoft Xbox 360 Console
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Network printer
Connect one end of an ethernet cable into the ethernet port on the printer and the other one into a free port on the router. Then, using the install CD, tell it that you are attaching a printer on the network. The software should automatically detect the printer on the network and set itself up for it.
Jun 26, 2008 | Computers & Internet
Linksys keeps disconnecting
Have you tried different ports on the router? If so have you tried other computers hard wired in? Hard wire in one of your laptops for awhile and see if they lose connection as well. If so then the problem is the router, but if they can stay connected then I would try either updating your network card drivers or getting a new network card perhaps. Let me know if that helps any.
Sep 25, 2007 | Linksys Wireless-G Broadband Router
D-Link DIR-625 (790069292637) Wireless Router Logo
428 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
