There could be a few reasons why your Cadco convention oven isn't producing steam. Here are a few things you can try to troubleshoot the issue:
- Make sure the water reservoir is filled. The oven won't produce steam if there's no water to create it.
- Check the steam valve to ensure it's open. If it's closed, the steam won't be able to escape the oven.
- Clean the steam generator. Over time, mineral deposits can build up in the generator, reducing its efficiency.
- Check the heating element. If the element is damaged or not functioning properly, it could be causing the wheezing noise you're hearing.
If these troubleshooting steps don't resolve the issue, it's possible that there is a more serious problem with the oven. In that case, it may be best to contact a professional appliance repair service for further assistance.
