see this causes and fix it. God bless you
First check is the main
fuse of the unit. On countertop units, you will need to take the shell
off. The fuse will be close to where the cord comes through into the
unit. OTR units, this main fuse is usually behind the control panel or
possibly behind the vent. Usually the fuse is obvious if blown,
otherwise test with an OHM meter, if open, replace fuse.
Some
brands will also have a thermal cut-off fuse in the incoming voltage
line to the control board. Older Maytags and Samsungs have this fuse in
it. This thermostat looking fuse is usually above the oven cavity
somewhere under the outside shell. Sometimes you can get to it through
the vent of OTR models. Test with an OHM meter, replace if open.
