Hi Smrit, If you've over charged your MP3 Player then this might help. I know if you over charge a cell phone or tablet to often the over charged battery will malfunction, The link below is a youtube video on how to fix a phone or tablet that won't turn on..... CHEERS How To fix any Android Phone Tablet that won turn on
try ebay.com or www.kijiji.com or www.kijiji.ca if in Canada for parts and or service, perhaps broken or cheap units on kijiji whch is a free local site for ads.
I assume the doors can be manually locked. The problem is in the electrical circuit. That means anything from a faulty switch (the lock / Unlock button) to a loose connection. If both switches don't work then look for a blown fuse. If one switch works and the other doesn't than remove the switch and inspect its connection. If it's ok then check the switch. If both switch and connections are OK then you'll have to remove the door panel and access the lock mechanism.
You should use Philips device manager to repair your player. Unfortunately the contents will be removed by using this repair function. How to do this is described here:
Won't start with the key? The issue is with the car. Won't REMOTE start, the issue may be with the hood pin switch (located under the hood) or, if it's an older system, the issue may be with a toggle switch under the dash.
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
