To perform a hard reset on a Pioneer CDJ-400, follow these steps:
1. Turn off the CDJ-400 by pressing the power button located on the front of the unit.
2. While holding down the Eject button (located on the top left of the CDJ-400), turn on the power switch.
3. Continue holding the Eject button until the display shows "PIONEER CDJ-400."
4. Release the Eject button.
5. Press and hold the Track Search Forward (">>") button and the Track Search Backward ("<<") button simultaneously.
6. Keep holding these buttons until the message "Resetting All Data" appears on the display.
7. Release the Track Search buttons.
8. The CDJ-400 will perform the hard reset and return to its factory default settings. This process may take a few moments.
9. Once the reset is complete, the CDJ-400 will restart.
Please note that performing a hard reset will erase any custom settings or saved data on the CDJ-400. Use this option with caution and make sure to back up any important data before proceeding.
Take off the slider from the main board and clean it with IPA solution, blow dry it take care not to scratch the carbon strip inside after that apply a very small speck of petroleum jelly or mechanism grease, used by technicians on the movable mechanical parts and you may get it working again. If you have the patience and the knack of doing it urself go ahead. If not order a new slider ( send the details correctly including the size and ohms rating) and replace it. After all pitch bending should not keep changing if you are a DJ so a new one would be most feasible in your case.
