Sounds like the sensor arm has got damaged or bent and probable will need to be replaced. But before that try to clear the unit of any jammed paper with tweezers. I would also advise to give a good spray with WD-40 which will help loosen and soften the stuck paper and lubricate the rollers,. Hopefully clearing alone will solve the problem, otherwise you will need to replace the sensor
