The meaning of error code F6 can vary depending on the brand and model of the washing machine. Here are some possible explanations for F6 error codes on different brands:
Whirlpool: F6 error code on Whirlpool washing machines typically indicates a problem with the motor drive tachometer, which measures the motor's speed. This can be caused by faulty wiring or a failed motor control board.
Kenmore: On Kenmore washing machines, F6 error code can indicate a problem with the motor or motor control board. This can cause the washing machine to not spin or agitate properly.
Maytag: F6 error code on Maytag washing machines can be caused by a problem with the communication between the central control unit and the motor control board. This can cause the washing machine to not start or complete a cycle.
LG: On LG washing machines, F6 error code can indicate a problem with the motor or motor control board, or a communication error between the main control board and the motor control board.
It's important to consult the user manual or contact the manufacturer for more specific information and troubleshooting steps based on your specific model and error code.
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
I believe f6 ec temp is your code. That means the electrical compartment is getting to hot. Most common is the fan on the back of the oven is weak and not moving the air fast enough. Also the electrical compartment could be loaded with dust.
Normally the F6 code means a shorting cook relay. That can be repaired for $39.95 in most cases. But it would be best if we knew your full model number from the cooking cavity or elsewhere on the oven.
If your washing machine indicates fb or F6.. here's what i always do.. Make sure your washing machine has connected to the power socket.. To switch on your washing machine Hold the power button of the washing machine and at the same time switch on the power socket.. Voila! It works! Do take note that by doing that it does not fix your washing machine but it helps to overcome this issue..
