We are looking for the jet holder for the large front burner on a Heartland Stove 7100
SOURCE: GE Spectra JBP64BB front right large burner won't work anymore
how are you the GE Spectra JBP78 Electric... Problem: Subject: the proble is that i had a shortge of power and i have the ""lockdoor"" showing
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
