Not sure what this time warner internet cable is ?
It should not interfere with an internet connection you might have to configure the connection again.
You will have to open up
your network connections
Click start control panel
network connections this may vary depending on your operating system look for
local area connection if you see a red x or a yellow exclamation or question
mark !
you will need to update or
install the driver or it could be firewalled.
Make sure your antivirus
program is not blocking the internet connection.
If you are trying to
connect through a modem/router you it should have come with a disk then
you might have to connect
the usb lead to your modem to get a connection then
administration tools computer management device manager scroll to network
adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the
disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the
BIOS if you cant install the driver.
Make
sure you Ethernet/internet is enabled in bios restart your
computer during the boot up process you will see on your screen a certain key
to
press
to enter set up (BIOS) press and hold that key to enter bios using arrow keys
navigate to integrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press
enter make sure its
"Enabled"ima
Click start type cmd press enter
you will be in DOS mode
type in ipconfig press enter you will see all of your
internet connection details type in your default gateway adress into your
internet search should read something like 10.0.0.138
or
you could download one
SOURCE: my e machine computer
Check the VGA cable - it's usually a blue head, and connects to your PC. Sometimes one or more pins can get bent out of position and cause the monitor to not function.
To fix this problem, simply grab a set of needlenose pliers and reset the pin to its proper upright position. This will take some muscle energy, but does not need to be perfect, as the pin will straighten out fully once re-plugged in.
SOURCE: Emachine sends & receives email, cannot connect to Interner
If you are able to get e-mail, you are connected to the internet.
Are you saying that you browser will not open to the site you have chosen? Try clearing the cache (in Internet Explorer you have to go to tools and internet options and then delete your temporary internet files. This may solve your problem.
You should also go to the security tab and reset the security settings to default.
If these don't work, you might have a software firewall preventing you from connecting.
