SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
