Televison & Video Logo
Posted on Apr 23, 2009
I need to remove child lock (without remote)
My friend pressed buttons too fast on my Wharfedale WH-TV21PFJ TV and accidently activated child lock! How do I remove it? I no longer have the remote for the TV either! PLEASE HELP!! I have a rca tv and myson put the parental lock on . standby light on but tv wont come on and i dont have remote
Claudine Venter
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 16, 2018
Claudine Venter
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1872
Points
Any answers on the problem?
Jacques Adams
Level 1:
New Friend:
  • Posted on Feb 21, 2016
Jacques Adams
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1872
Points
Universal remote...that's the ONLY other option. SERIOUS... I've tried everything... lol
Anonymous
Level 1:
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1872
Points
6
Hi did you get to solve your problem becuase i have the same problem
Hello !! Friends i need to know how to remove key lock from grundig tv model gu26dvd. .with out using a remote control. Thanks
Hello! I'd be happy to help you.
To remove the key lock from your Grundig TV model GU26DVD without a remote control, you can try the following steps:
  1. Turn on the TV using the power button on the TV itself.
  2. Press and hold the MENU button on the TV for several seconds until the menu appears.
  3. Use the volume up/down buttons to navigate to the "Lock" or "Child Lock" option and press the MENU button to select it.
  4. Enter the four-digit password using the number buttons on the TV. If you don't know the password, you may be able to find it in the TV manual or by contacting the manufacturer.
  5. Navigate to the "Off" option and press the MENU button to select it.
  6. Press the MENU button to exit the menu.
If the above steps don't work or you don't have the manual to find the password, you may need to contact the manufacturer or a professional technician for assistance.
HOW TO UNLOCK CHILD LOCK OFF TO WHARFEDALE TV
Dear sir
I was watching tv and my sister said "jayden put in the dvd" i said ok .i struggled and struggled and i press any button i just sore child lock
Can you please help me sir
2answers
7answers
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
I accidentally activated my Wharfedale WH-TV25NJ childlock, can you help please? the remote control is out of order as well. Thank you George
If you did not press any button while in the child lock it can be remove. Try to look for your manual, it has a default code in the manual.
2helpful
My tv logik lk 74n has locked. please help me procedures of removing the padlock symbol.
The Red Lock indicates that it has been Child Locked, this could be done by accidently pressing child lock. On your remote control there is a MUSIC button, to turn off the red child lock PUSH & HOLD the button. The red lock does not go off with a qucik push. You need to Push & Hold The music button for about 10 secounds.
Read more: How to unlock my logik tv , it has a red lock on the corner with a blue screen and i cannot use my remote or the keyboard to activate the menu ' Answerbag http://www.answerbag.com/q_view/516852#ixzz289vnGLRC
2helpful
Childlock on and i dont have the remote control for it any more how do i remove child lock ,TV Wharfedale WH-TV21NJ
You may not be able to remove the child lock without the remote. (as that is the whole point of it..lol) your best bet is probably to pick up a cheap "one for all" remote and see if that will remove it.
I accidently put the child lock on the magnavox tv how can i get it off with a universal remote?
Depend on your remote would be easier with the remote that came with the TV. Can you acses the TVs menu with your universal? if not I don't think there's anything you can do. if yes, this how you do it:
1 Press MENU to show the on-screen menu.
2 Press VOL+ or VOL- repeatedly until SET is highlighted.
3 Press CH+ or CH- to highlight CHILD LOCK.
4 Press VOL+ or VOL- to choose ON or OFF. Choose ON to disable all the buttons on the front of the TV. CHILD LOCK ON will appear briefly on the TV screen each time you press a button on the front of the TV. You can still operate the TV with the remote control.You can still use the POWER button on the front of the TV, but only to turn off the TV (not on). Set CHILD LOCK to OFF to cancel this feature so you can use the buttons on the front of the TV again.
5 Press TV/AV/EXIT to remove the menu from the screen.
4helpful
2answers
How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
