Question about Arrow CHROME STAPLE GUN ARROW IND. STAPLERS
The staples do not enter the wood completly
The staple enters the wood 1/2 to3/4 way into the wood.
  • Anonymous May 05, 2009
    my sharpshooters ist a disambled
    Problem Solver:
  • 9 Answers
Often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Posted on Apr 22, 2009
Anonymous
SOURCE:
No matter how i hold the staple gun the staples won't go into wood. when they do the staples aren't flat they bend in the middle.this gun has never worked correctly.could i be using it incorrectly?
possibly that you are not using the correct staples
staples for wood have a chisel shape at the points and depending on the wood hardness will be shorter that normal
Jan 28, 2017 | Tools & Hardware - Others
How do I remove pneumatic staples from furniture.
try a large pair of pliers.
straighten the staples as much as you can, grip one leg with the pliers about 1/8" from the wood, and tap the pliers with a mallet or wood block.
alternate "till you can grip the crown.
Jan 11, 2015 | Chicago Pneumatic Air Tools & Compressors
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
T59 arrow stapler doesnt set staples all the way into wood
Is this just on one piece of wood or does it act that way on all kinds of wood? Some wood is denser that others and that would cause the staple to not go completely into the wood.
Jan 13, 2014 | Arrow T59 Cable Stapler For Insulated...
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
What size staples and what size Arrow stapler do I need to stable coaxial cable
I would use 1/2 inch or larger. Set the staple into the wood and then pull gently to see if it holds.
Jan 06, 2011 | Arrow T50P ARROW STAPLE GUN
The side of the staper lists 3 different staple sizes, does it really take all 3? (1/4, 3/8, 1/2 inch)
Samantha, Yes. These sizes are the lengths of the legs. They are all the same size wire, bent into the same width of "U". Yes, it will take all 3, but you have to buy the right type. When you buy staples, look for compatibility with this brand & model stapler. By the way, if you a stapling something thin to something substantial (such as paper to wood), use short staples. Otherwise you will have difficulty getting the staple to penetrate the wood sufficiently for the staple to lay flat. Good luck, Al K
Dec 08, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Tr250 does not drive brad nails all the way down.
Jason,
I think this is typical of these staplers/nailers. I bought a lighter model Stanley the first time and had this problem. I took it back and exchanged it for the heaviest Stanley they had at Home Depot and had the same effect. It drove the stapler a little deeper but not all the way.
I did find that if I put all the down pressure on the stapler right on the edge where the staple comes out and then pull the trigger it would drive the staple almost all the way in. I think that there is a recoil effect (like with a gun) when you pull the trigger and the staple enters the wood. Try this. it will help.
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate Thanks for using FixYa
Nov 06, 2008 | Stanley TR250 H Heavy Duty Heavy Duty...
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Arrow CHROME STAPLE GUN ARROW IND. STAPLERS Logo
288 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Charles Tidwell
Poul Brinchs Larsen
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
