When you leave a message via the message pad to be heard at a later time, the message is not understandable. You can hear the person's voice in the background but it is covered by a lot of static.
No, I am afraid it is not that simple a solution. I suspect that I will have to replace the smartboard if that is where voice messages originate from.
Is there a fan or another noisy device running in the background when you leave the message? You might contact call the GE Answer Center at 1-800-626-2005.
The only way possible to see if the touch pads are working is to test the voltage of the control pads when it contacts. The input of the Microprocessor should be checked for the pad control impulse to come in. If there is no trigger voltage to the mP this can be the control pad problem.Some dirt can accumulate and cause the tracks to short resulting in this display. Try to use heater to warm off any moisture.
The mP must be checked for the working voltage and also the frequency oscillation at the crystal leads. If so the mP is working with a suspected control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to have a chance is to remove the carbon sticker pads and check continuity , You can use a carbon pen to line the tracks so that the multi-meter reads a continuity. With this you can have a temporary fix
