Just replaced the bulb (the new one did not come with screws for the lamp housing) and when I went to turn it on there was a lamp light (yellow and flashing) it eventually stopped flashing and I tried to turn it on, I heard something seemingly shatter and a loud humming noise coming from the bulb area. When I removed the bulb it seemed to be ok and in working order. What do I do? I love this tv and don't want to loose it... PLEASE PLEASE P L E A S E HELP ME
Contact any service technician.
Testimonial: "^REALLY *****!?!^ THAT'S NO HELP! I did some more research and found it was the color wheel. Being as that its an older model (6 years old) it has been harder to find parts and even harder to find helpful videos but I have been able to remove the color wheel and am waiting to order a new one through shopjimmy.com I will follow up again with end results. Hopefully no more morons with a day off trying to get holiday pay from tech support put any idiotic posts."
SOURCE: Lamp Light flashing Yellow
double check the lamp.make shure the 2 wires were installed correctly.Also check the plug inside the tv where the lamp plugs in.They have a nasty habbit of coming loose.
SOURCE: wd-52531 has sound, then clicks off after few seconds
It can be the lamp. But the color wheel and ballast can cause the same thing. Put your ear to the back of the set when you push the power button and you should can here the color wheel start up. If not, that is your problem.
Now if the lamp is not lighting up. you should here a ticking sound from the back of the set, if not the ballast is bad. If the lamp is coming on and then going out after only about 5 seconds AND you do not here the start up of the color wheel, the color wheel is confeirmed bad.
SOURCE: Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
SOURCE: Getting a loud buzzing noise in the rear of my
I have just experienced the same issue with my mitsubishi WD62525 as well...thought it may have been a lamp issue as well....replaced the lamp with the spare and still have the same symptoms...(only difference is that my timer light just continues to blink green and never turns red???) I cleaned out the rear filter...was not really that dusty so not sure what else it may be????
