You probably want to connect the av Audio output from your tv and connect to the RX-V5000. The audio that you are getting from Radio through the tv is probably coming from the output of the RX-V5000 coming to your tv, to which the desiredd route is the other way.
The Outputs at the back should be labeled to tell you which channels are inputs or outputs.
SOURCE: I would like to know how to connect my Bose 901 to
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
SOURCE: Yamaha RX-797 iPod Integration
I have a question first... are the 901's amplified by a separate amp as they should be in a multi-channel (non-stereo) setup?
Better yet read the following then decide if you have iy set up right to begin with. If so, I'd just treat the Ipod or Mac as auxilliary inputs on the receiver. :
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
SOURCE: I have a Yamaha RX-V992 receiver and I would like
Basically here are the connections you have to do:
In case you don't have tape recorder forget the "box" named tape recorder. Your RX-V992 is the box named receiver or preamplifier. You have to connect with RCA - RCA cables the tape out from the RV-X992 to Bose input, and the Bose output to tape in at RV-X992. With the setup connected like this whenever you choose from the RV-X "tape monitor" you will hear the sound equalized from Bose; if you disable the "tape monitor" switch you will hear without any equalization.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: I have a Yamaha RX-V765 which is about 2 weeks
i just dont know how to put on zone 2.... its like i put it in zone 2 and nothin happens... can someone help me this is starting to **** me off..
SOURCE: Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
