Question about Dell Inspiron 8600 Notebook
Dell Inspiron n5050 screen backlight not working
6ya staff
SOURCE:
Anonymous
  • 49 Answers
SOURCE: Dark area on left side of screen of Dell Inspiron 1525
Do you have the CD's That originally Came with the Laptop? If so, put that in before you start your computer and boot from cd. While your computer is starting up it should say "Press any key to boot from cd" Press a key to load the Cd Diagnostics Program.
If not, go to support.dell.com - Click on Drivers - It will ask you for the "Express Service Code" of your laptop, which is marked on a label on the bottom of your laptop. Here you can download the Diagnostic tools (found on the cd) in the case you do not still have the cd.
Run the entire set of diagnostic tools. (They are very intuitive and easy to run) If they come back with a specific error code, you will know what the problem is.
You can then contact dell with the code & or the symptoms you are having at their number 1-800-624-9896 which is 24/7.
The problem could be a handful of things.
1) There is a plug underneath the laptop keyboard that may have came loose which can cause the dim image.
2)The graphics card has become dislodged & or overheated
3) The cord between the motherboard & Screen has become frayed.
4) The Backlight (lights right behind the LCD screen have gone out on the 1/3 of the screen) This scenario is only the cost of the lights and labor to replace them.
Tech Support will be able to narrow this down for you completely. If you do this on your own without them, you can void your warranty, in the case you have one.
Posted on Mar 13, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: where is the LCD backlight inverter on an Inspiron
The inverter is in the LCD, below the actual screen. It controls the brightness and the contrast on the laptop. Here is a link where I purchase them:
http://www.smartmicrousa.com/dell-inspiron-e1705-laptop-inverter-board.aspx
It is easy to replace. Here is a link that will guide you:
http://www.ehow.com/how_4841734_dell-laptop-inspiron-e-backlight.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 21, 2009
Anonymous
  • 244 Answers
SOURCE: dell inspiron 5160 labtop backlight
It seems to me the inverter is busted. That is why the backlight just went out. If you are still covered by your warranty Dell technical support will replace the inverter and i believe they will also include the LCD kit.
Hope this helps
Posted on Jan 16, 2010
specialistel
  • 8909 Answers
SOURCE: hi. i have dell inspiron
The invertor or ballast unit is usually fitted at the base of the screen. Taking the front bezel of will reveal it.
Hope this helps.
Posted on Oct 23, 2010
SOURCE: take apart
Get some cups and label them with the screws that you remove from the laptop. Start removing screws from the bottom of the laptop. A digital camera would be handy to take pictures of things before you remove them.
Posted on Apr 21, 2012
How to clear a HDD password on a dell inspiron 5110 laptop please help
I Googled for a solution online
Solution 1: dell.com support requires owner ship proof and i don't have it.
Solution 2:www.dellpasswords.com website seems to have the password, and i will try that.
Jan 18, 2014 - HDD password for Dell Inspiron 15 N5050
Dell Inspiron 15 N5050 BIOS Password:
I bought the Bios password from http://dellpasswords.com/ and received it with 5 minutes,
the password worked & the motherboard is unlocked,
It seems to me that I now need the hard drive password,
wasn't expecting that .
Dell Inspiron 15 N5050 Hard drive Password: or
Feb 04, 2015 | Dell Computers & Internet
My dell laptop Inspiron N5050 is no longer gettin a signal from the hdmi cord to the toshiba flatscreen tv
Try updating or reinstalling the video driver go to this link
Support Dell US
you can put your service tag or select your model inspiron n5050
and select operating system to see which video driver is your download and install. hope that helps
if all else fails do a system restore back to the date it was working fine
Aug 02, 2014 | Computers & Internet
Where can i get a universal password to unlock my dell inpiron n5050
I never heard about a Universal password. Remove the CMOS battery, wait about to minutes, reintall it and it should reswet bios and you should have access to your computer
Apr 16, 2014 | Dell Inspiron 15 (N5050)
I need the hdd password to unlock my dell inspiron n5050
T is the password to unlock the hdd on a dell inspiron n5050?
The only way of retrieving any files from a password protected hard disk without knowing the password is to send it to a data recovery company for unlocking, but not all data recovery companies could or would unlock a password protected HD
Dell inspiron n5050 no power on
very likely your main board is gone. Get help from local computer store to fix the computer. It could be your charing port or even your ac adapter, Make sure use another ac adapter and see what happens.
Dec 27, 2013 | Dell Inspiron 15 (N5050)
Dell webcam
reinstall windows or go back to factory settings.
May 05, 2013 | Dell Inspiron 15 (N5050)
My dell inspiron n5050 automatically hibernates after booting
on start up togglr F8 key when screen comes up choose start in safe mode once it gets to main screen right mouse click in center of scren pick personalize click on screen saver and go to change power settings and see what hibernation is set on and set it higher restart and see if problem is solved
Jan 19, 2013 | Dell Inspiron Computers & Internet
Dell Inspiron 8600 Notebook Logo
Ekse
Clive
Clive
Alun Cox
