Nokia 3110 says Invalid web settings when i try to connect to internet either some one helps me this problem
SOURCE: My new unlocked nokia 6288 cannot connect to gprs
to connect to the internet or set up email or to send mms you must activate the GPRS first from your
network provider ...The best thing you can do is to contact the
customer care of your network provider and ask for the activation of
GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you
will receive the gprs settings(profile) also ... make sure of the
charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if
the customer people tell you that your handset is not compatible for
the receiving of the profile settings then you must tell them to give
the manual settings(includes ip address,APN,etc) so that you can only
create the profile and input the information given by the customer care
people...
if you have already subscribed the GPRS then call the customer care of
your network provider & ask for the settings by telling your model
of the handset ..
any further doubts reply me
i am always here to assist you ..
thank you
bye...
rate my solution
SOURCE: My Nokia 3110c mobile is
There is a Software problem in your mobile you should renew your mobile software.
If
your a Mobile technician then use the software box & as well as use
the suitable cable of your mobile e.g JAF Software dongle box and
cable. By using this you can renew your mobile software. If your Not a
Mobile Technician the dont try this thing it is harmful for your mobile
it may become dead.
If your not a mobile technician then please
visit your nearest Nokia Service Center ( Nokia Care) they will do it in
proper method.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
SOURCE: when i start internet by pressing 0 on nokia 3110 it replies invalid web settings
you need to select the settings from the settings you have
having settings is not enough you need to make it the default setting
