Samsung Galaxy GT-S5570 Logo
muhammed golicha huqa Posted on Oct 08, 2013
Language settings - Samsung Galaxy GT-S5570
Thomas Boll
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 08, 2013
Thomas Boll
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
309
Points
18
What problem do you have with the language settings?
How do I fix language to English on ***** in paradise shiw
To change the language to English on the "***** in Paradise" show, you'll need to check if the show or streaming platform offers language options. Here are some general steps you can follow:
  1. Access the settings: Look for a settings or options menu while watching the show. This is usually represented by a gear icon or the word "Settings" on the streaming platform.
  2. Language settings: Navigate to the language settings within the settings menu. It may be labeled as "Audio" or "Language."
  3. Select English: Once you're in the language settings, look for English in the list of available languages. Choose English as the preferred language for audio or subtitles, depending on your preference.
  4. Save and apply changes: After selecting English, save your changes and exit the settings menu. The show should now be playing in English.
Note: The steps may vary depending on the streaming platform or device you are using. If you're unable to locate the language settings or encounter any difficulties, consult the platform's help or support documentation for specific instructions.
Additionally, if "***** in Paradise" is a show that is dubbed or subtitled in multiple languages, ensure that the English option is available for that specific show or season. Not all shows may have language options for every language.
If you're watching the show on a television network or cable provider, you may need to refer to the instructions or settings provided by the network or provider to change the language settings.
Remember that some shows may only be available in the language they were originally produced in, and language options may vary depending on your location or the rights acquired by the streaming platform.
tip
China Phone Secret Codes
<span><b>Fast Unlocking</b><br /><br /><b>CHINA Mobile Phones Secret Codes</b><br /><br />Default user code: 1122, 3344, 1234, 5678<br />Engineer mode: *#110*01#<br />Enable COM port: *#110*01# -&gt; Device -&gt; Set UART -&gt; PS Config -&gt; UART1/115200<br />Factory mode: *#987#<br />LCD contrast: *#369#<br />Restore factory settings: *#987*99#<br />Software version: *#800#<br />Software version: *#900#<br />Set default language: *#0000# Send<br />Set English language: *#0044# Send<br />Set English language (new firmware): *#001# Send<br /><br /><b>Service codes Fly:</b><br />2040(i) reset defaults: *#987*99# Send<br />M100 software version: ####0000#<br />MX200 reset defaults: *#987*99# Send<br />MX200 software version: *#900# Send<br />MP500 reset defaults: *#987*99# Send<br />MP500 software version: *#900# Send<br />SL300m reset defaults: *#987*99# Send<br />SL300m software version: *#900# Send<br />SL500m reset defaults: *#987*99# Send<br />SL500m software version: *#900# Send<br />Set language to English: *#0044#<br />Set language to Russian: *#0007#</span> <span><br /></span> <span>*#66*# Set Factory Mode CONFIRMED<br />*#8375# Show Software Version CONFIRMED<br />*#1234# A2DP ACP Mode CONFIRMED<br />*#1234# A2DP INT Mode CONFIRMED<br />*#0000# + Send : Set Default Language CONFIRMED<br />*#0007# + Send : Set Language to Russian CONFIRMED<br />*#0033# + Send : Set Language to French CONFIRMED<br />*#0034# + Send : Set Language to Spanish CONFIRMED<br />*#0039# + Send : Set Language to Italian CONFIRMED<br />*#0044# + Send : Set Language to English CONFIRMED<br />*#0049# + Send : Set Language to German CONFIRMED<br />*#0066# + Send : Set Language to Thai CONFIRMED<br />*#0084# + Send : Set Language to Vietnamese CONFIRMED<br />*#0966# + Send : Set Language to Arabic CONFIRMED<br />CHINESE MODELS:<br />default user code: 1122, 3344, 1234, 5678<br />Engineer mode: *#110*01#<br />Factory mode: *#987#<br />Enable COM port: *#110*01# -&gt; Device -&gt; Set UART -&gt; PS Config -&gt; UART1/115200<br />Restore factory settings: *#987*99#<br />LCD contrast: *#369#<br />software version: *#800#<br />software version: *#900#<br />set default language: *#0000# Send<br />set English language: *#0044# Send<br />set English language (new firmware): *#001# Send also</span> <span><br /></span> <span>also it will helps you thnx</span>
on Jul 12, 2011 • Cell Phones
1helpful
Garmin Drive 51. Screen is in a foreign language. How do I get it into English?
Language and Keyboard Settings To open the Language and Keyboard settings, from the main menu, select Settings > Language & Keyboard.
Voice Language Sets the language for voice prompts. Text Language Sets all on-screen text to the selected language. NOTE: Changing the text language does not change the language of user-entered data or map data, such as street names. Keyboard Language Enables keyboard languages.
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Mar 25, 2018 • Garmin GPS
1helpful
I have a nokia e51 i want to make it arabic .... how can i make it..
go to settings menu->language settings->
Language settings
To set the language used on the device display, select Language > Phone
language.
To select the language in which you write notes and messages, select
Language > Writing language.
To select whether to use the predictive text input, select Language >
Predictive text.
3helpful
How do I change the language setting to english on
hello
you can try these steps to change your phone's language
Language settings
Select Menu > Ctrl. panel > Settings and General >
Personalisation > Language.
• Phone language — Set the device language.
• Writing language — Select the language used for writing notes and messages.
• Predictive text — Activate predictive text input.
• Input options — Define the settings for predictive
text input.
15helpful
4answers
Change language
to change the language, enter the phone menu, go to settings, scroll to phone, and select.
You will see the language settings there and your can change the language.
Take care.
10helpful
4answers
Someone has set my phone another language. How do I change the language to English
Go to menu. You know the setting icon right. Click on that icon.In that one select first ooption named general settings. in that ,you want to select third option will be the language option in that one you can see the english option.....Hope this will helps you...Thank you...
1helpful
How to change the langue
Set the display language
In the device options, click Language. In the
Language field, click a language. Click Save.
About the input language
You can set an input language to use when you type.
This setting is different from the display language.
When you set an input language, AutoText and other
typing settings change to the selected language.
Set the input language
In the device options, click Language. In the Input
method field, click a language. Click Save.
Related topics
About the input language (See page 79.)
Set the display language (See page 79.)
Add or remove a display language
If your BlackBerry® Handheld Software supports
multiple languages, you can add and remove
languages using the Application Loader tool in the
BlackBerry Desktop Software. See the BlackBerry
Desktop Software Online Help for more information.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
