SOURCE: futura ce 200
I had the same problem and found that the feed dogs must be in the lowered position otherwise nothing will happen,remove the embroidery unit and check the selector and try again,
SOURCE: please help
I have the CD, but have just posted a message about the driver not working in the install. So, if you want, I can try to send you a copy, but it's not sure it'll work...
SOURCE: I have a Singer Futura CE-150 and it keeps
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
SOURCE: Singer CE-150 Futura can not locate driver
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
http://www.futura-support.com/downloads/ce150.html
SOURCE: Will Mac run Singer® Futura
The software doesn't run on MAC. And you can't get a download directly off the internet, at least not anywhere that I've found. When I couldn't find my disk a few months ago all of my research told me that I had to purchase a replacement CD from Singer.
