Reinstall the WiFi driver:
Lenovo Support Drivers Software US
Alternatively, you can Enable/Disable WiFi by opening:
Control Panel>Network and Internet>Network and Sharing Center>Change Adapter Settings
You should see your WiFi connection listed. Right Click to Enable or Disable.
SOURCE: wi-fi connection
Looked at the specs on your laptop and you have the wireless card included. I assume you have a router set up already or you have access to another wireless network. Follow these steps to access it from your laptop:
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
SOURCE: WI Fi Problem
Here are two drivers I managed to find for you, they're on lenovo's website fyi.
1) If your wireless adapter is Intel
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63547
2) and if it is BroadCom
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63550
Hope this helps, stay spicy and happy lappying! :)
SOURCE: Bluetooth is not working in Lenovo 3000 y500 notebook
Try restoring your computer to earlier time using System Restore,
on Explorer click Help menu - Help and Support Center and select Undo changes to your computer using System Restore.
SOURCE: switch on the wireless device first?
PLease locate the slider switch at the edge of your laptop. there should be a small slider switch for your wireless. Try to look at the sides or at the front of your keyboard.
Testimonial: "right but very late..anyway thnx"
SOURCE: Lenovo T61 Wireless not connected
To turn on the wifi card. Make sure that the driver is install the press FN + F5.
Thanks for using Fixya.
