Toshiba 55H70 55" Rear Projection Television Logo
Kimberly Hull Posted on Feb 25, 2018
Toshiba 51h84 will not show picture. You can tell it is "trying" to pick up the satellite picture, but it will not show it or play audio. Was working fine, then just started showing white noise. We did plug up another tv with the same cables, so we know the problen is not with them.
3 Related Answers
Anonymous
  • 65 Answers
  • Posted on Dec 09, 2006
SOURCE: Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Anonymous
  • 3130 Answers
  • Posted on Dec 15, 2006
SOURCE: toshiba 51H84
I would not replace the convergence ic's just yet. first, pull off the CRT sockets off the picture tubes and lay them aside, making sure they are not touching anything. Next disconnect the Plugs off the convergence board, where the STK IC's are. Next see if the set will turn on now with sound. if it does, replace the convergence IC's. If it does not check the sweep power supply and or the main regulator IC and circuit. Good Luck Please do not forget to rate this thread.
Anonymous
  • 1738 Answers
  • Posted on Nov 23, 2009
SOURCE: Toshiba Theaterwide HD 51h84
It is your projector tub if you are getting alot of blue in the picture. Those guns are very expensive to replace. I am sorry to tell you that. It would be cheaper set from wal-mart for your kids to play on.
Internal interference
ok you can used the matching transformer to avoid the interference. or you can buy a 'interference free'at the electronics stores!
My toshiba 51H84 has picture but no sound,was watching heard a snap like static then no sound.
sounds like either a transformer or somthing that handles the output for the projectors got blown
1helpful
How do i replace a dvd rom drive in toshiba satellite a85 s1072?
There are one of 2 things that are happening. One, the reader on the CD drive is dusty, so carefully check the head, it is a luminescent bulbish thing in the middle of the open drive. Otherwise, your CD's (including past cd's) may have been dusty, and damaged the drive, in which you need to replace the drive. If your computer is under warranty then send it back and tell them this.
Good Luck
I am getting no sound through my satellite receiver
switch your scart lead around i,e the one that gose to tv noe goes to sat box
Toshiba laptop sound
If you are using media player to listen to your audio files then go to 'view' 'show enhancements' and make sure the graphic equaliser is set how you want it, while here click on 'default' and lots of options will come up on how you want to listen to your music.
hope this helps
Toshiba 51H84 - Black Screen
try unplugging it and plugging it back in, if that doesn't work make sure that your ANT. cable is plugged in and then check your reciever. Tell me how it works :-)
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
The solution is you have to buy a new better tv with a good extended warranty in payments. JZ
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
