My desktop will not boot. It goes to the the blue screen. when I preformed the test every thing passed. The warning was under Boot Patch: Error code BIOHD-2. No drives detected.
Error
Code Biohd-2 No Drives Detected errors are caused by missing system files or
broken system registry structures. This is a critical sign of an unstable
system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk
utility
Click start run
type cmd then type chkdsk/r/f which will scan for and attempt to
repair any bad sectors and automatically fix any corrupt files on your Hard
Drive.
or an easier way to run the
chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer
management ,disk management right click on your drive select properties click
tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of
bad sectors place then a tick in both boxes then select check now, start should
schedule this task when restart
have no input while the chkdsk utility is in progress any
input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry,
gets rid of junk files, deletes broken shortcuts, and attempts to give your
computer that like-new feel again.
Optimizers
and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html
5E3422139C19CBED35C14826A44D4605
Improve your PC performance and
fix errors.
If you are unable to get a
connection with your hatd drive
Restart your computer repeatedly
tapping the f8 key to enter safe mode while the screen is black once in safe
mode where the only things working will be your keyboard and mouse allowing you
to attempt to repair your computer
If done properly the user should
get to a screen similar to the below screen.
Select the option for Safe mode
command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your
choice.
Select safe
mode with command prompt then type in chkdsk/f/r which will scan for and and
attempt repair of bad files and bad sectors on hard drive
You should
have no input while chkdsk utility is in progress any input might further
damage your computer also
Use the System File Checker tool (SFC.exe) to
determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER:
sfc /scannow The sfc /scannow command scans all
protected system files and replaces incorrect versions with correct Microsoft
versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
SOURCE: windows doesnt start
you need to restore your boot system by booting from windows installation disk.
whenyou boot fron CD and ask for repair , select install windows
after you accept the disclaimer by pressing F8, installation will search for current windows installation
after the search select RESTORE
SOURCE: When I turn on my
This is happening because the booting device sequence on your computer has got changed, due to some reason.
Booting device sequence settings, decide whether your computer will look for a boot medium from the floppy drive or from the hard drive or from the cd/dvd drive, etc in whatever sequence that is set in the BIOS settings.
If you are getting "Disk Boot Failure, Insert Disk" then the the floppy disk drive has been somehow put as the 1st device in the BIOS boot sequence settings.
This has to be changed to hard drive as the 1st device in the BIOS boot sequence settings.
It would have really been very useful, if you mentioned the make and model of your desktop, so that I could have given you exact steps to follow. However, to correct the issue, typically the foll. will have to be done :-
• Hit DEL (on some computer brands, it may be F2 , F10 or F12 hey) or any key that prompts to enter the BIOS
The following message is usually displayed when you power up your computer:
Press to enter Setup. is normally [Del], [ESC] or any other keys depending on the BIOS that comes with the computer.
• In the BIOS menu, look for Boot Sequence
• Select your required boot device to be the first boot device.
Please select Hard Drive as the 1st boot device.
• Save and exit the BIOS
• Restart the computer. The computer should now boot up fine. Then, please note :-
NOTE : in many cases a virus infection may have got the boot sequence changed, so please do run a full scan with the antivirus that is installed on your computer.
SOURCE: Windows freezes at startup window.
you may have to change a setting in the bios to make the computer boot from the cd instead of the hard disk
SOURCE: Computer does not see hard
reset the bios then check the power connector and the IDE or SATA cable for loose contact or change them see whether the hard disk is spinning or making any noise if you hear noise the hard dis is need ed to be changed if the hard disk is not spinning check the power connector and also check whether the circuit board below the hard disk is getting hot if its getting hot you need to change the circuit board of the hard disk with same company and number
