SOURCE: whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
SOURCE: Whirlpool Self Cleaning Oven - Model
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
