The original Homelite company has been out of business for many years. Getting parts for them at our repair shop is impossible. I know you can go and buy new Homelite units from the big box stores, but these are not being manufactured from Homelite. Sometimes you can find parts from repair shops that have leftover parts. You might want to call around. You might find them. George
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
SOURCE: Homelite XL 101, what are cc's?
cc stands for cubic centermeters..It is a measurement of the chamber that the piston resides in when totally expacted
SOURCE: I have a homelite xl, UT# 10655- the chain oil
Your saw is listed as an "XL Chain Saw UT-10655" here:
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
See the "Engine Internals" print. The oiler appears to above the clutch and driven by a pressurized tank. Venting the tank (opening the oil cap) may help help with weeping but only emptying the tank will stop it.
If no oil from engine oiler hole I suspect a failed hose or connection. Use the IPL to inspect and repair as needed.
Oil System Plugged.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Testimonial: "Thank you for your help. I'll follow your suggestions and see how it works out."
SOURCE: I have an earlier model Homelite XL Textron, UT#:
Hello cf:
I need your help to help you.
Please count the drive links on an existing chain and post back (below) with the number. I have to close this, to post a photo. We can continue if you just reply.
I will provide the correct bar size and a link where you can make a choice, because your saw is so old I cannot match it to anything currently on the Homelite site and I am not willing to recommend a chain without seeing your level of expertise.
You can also take an existing chain to a local saw shop where one can be fabricated in a few minutes.
Lou
SOURCE: chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Lou
If you need more help come back.Post /
thumbs / testimonial are
welcome!
